Need Help! CO2 Laser Beam iis just an "O" Ring
Results 1 to 9 of 9
Thread: CO2 Laser Beam iis just an "O" Ring
    Aug 2017
    Philippines
    Default CO2 Laser Beam iis just an "O" Ring
    Hi!I'm a new member here but I've been a long time lurker.
    The forums helped me alot these past couple of years with my laser cutters.
    But now I've encountered a problem that I have no solution for. Basically, the beam coming out of the tube looks like a big "O" instead of a dot.
    What could be the causes of this and what are the possible solutions for it?
    Thank you very much!
    Attached Thumbnails Attached Thumbnails CO2 Laser Beam iis just an "O" Ring-21013250_10155608952998607_852511579_n-jpg
    Apr 2014
    Default Re: CO2 Laser Beam iis just an "O" Ring
    I'm not a expert and really just spit-balling here but. wouldn't a dirty emitter or a damaged mirror cause this? the output is only allowed to come out if its in a cretin phase. so a patern like this would probably be caused by damage or dirt? maybe.
    This is right out of the laser right? not after a mirror.
    Aug 2017
    Philippines
    Quote Originally Posted by portabuddy View Post
    Yes right out of the laser. Will double check for dirt stuck inside the tube. Thanks!
    Apr 2014
    i was more thinking on the front emitter/element, but the other problem might be focus. has the laser tube been bumped? could the front element been knocked?
    Aug 2017
    Philippines
    That I am not sure of. My guy said it was working perfectly fine when he left the workshop and was like this when he got back today.
    I'm pretty sure that it would have to be a pretty strong bump to move the front element significantly.
    But I'll still double check. Thanks!
    Member oneeye's Avatar
    Aug 2005
    Brazil
    Quote Originally Posted by nuniksais View Post
    Bad news, the ressonator or output mirror of your tube gonne.
  7. #7
    Sep 2005
    If your mirrors are aligned correctly and your lens clean give it a try. It might be fine engraving or cutting. If not, its new tube time.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  8. #8
    Aug 2017
    Philippines
    Quote Originally Posted by oneeye View Post
    Shucks. If that's the case, good thing I have a back up tube lying around haha.
  9. #9
    Aug 2016
    Are you sure it wasn't like that before? That's perfectly normal for a number of different industrial machines I've worked on. All 2kw or greater power.
