need help for my laser power supply
Results 1 to 8 of 8
Thread: need help for my laser power supply
    May 2017
    Philippines
    Default need help for my laser power supply
    hi.. i have HY-C150-Y3 db9 port power supply.. how can i test the controller inside of the power supply that connect to main card of laser machine.if its good or not? pls help me. thanks
    Nov 2010
    Poland
    Default Re: need help for my laser power supply
    Quote Originally Posted by wmgeorge View Post
    Do you have the 120/240 volts connected?
    How can he use 120V version when Philippines use 220V?
    CNC lasers, constructions, service
    Sep 2005
    Quote Originally Posted by cinematic2 View Post
    Hey its rocket science, do you have power on the input side, either 120 / 240 volts?
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    endurance_robots
    Guest
    it could be an issue like this:
    or if you need additional PCB to run more powerful laser, please try this http://endurancerobots.com/azbnmater...-a-3d-printer/
    endurance_robots
    Guest
  7. #7
    *Registered User* Yovo88's Avatar
    Jun 2018
    Hi, How to connect power source hyc150y3 to controller card
  8. #8
    maybe you need transfer,uh,revised infos my whatsapp:+86 188 1628 1816
