Yesterday my new LG900N from G. Weike arrived. Today I got it uncrated and moved into the workshop with the aid of a couple of friends. Only took 15 minutes but then we spent 2 hours drinking beer and chatting - as you should.
I got the grease cleaned off and fitted the tube. It fired up as it should. Just needs an alignment and it's ready for use. The tube is a Reci W4 with a tested output of 115W.
Did my first cutting and engraving last evening. Need to tweak the alignment a bit but other than that the laser is operational and has started earning its keep.
This is my first time using RDWorks. I do find it an improvement over Lasercut and using it is straight forward.
