Newbie Having problems with engraving - May need a new laser
Results 1 to 4 of 4
Thread: Having problems with engraving - May need a new laser
    Oct 2016
    Coral Springs
    Default Having problems with engraving - May need a new laser
    I just bought a Universal Systems X30 with a 50 watt laser. The laser was replaced in 2013. I was using CoralDraw X6
    I am trying to engrave this image
    Having problems with engraving - May need a new laser-superman-black-white-png
    When I engrave it the black back ground does not engrave I have tried it on wood and acrylic
    Here is the what it looks like on wood this engraved a little on the top but then stopped. I used these setting to engrave it Power 100% Speed 20% and 500 DPI
    Having problems with engraving - May need a new laser-wood-jpg
    Here is what it looks like on the acrylic this engraved the whole box but was light and dark. I used these setting to engrave it Power 40% Speed 20% and 500 DPI
    Having problems with engraving - May need a new laser-acrylic-jpg
    Am I doing something wrong or do you think the laser is on the way out.
    Thanks for any help
    Mike
    Sep 2016
    China
    Default Re: Having problems with engraving - May need a new laser
    For acrylic , power is too high , try to use 300mm/s speed and 15-20 power ,400 -450DPI is OK
    For wood ,try lower DPI too .
    Triumphlaser factory supply laser cutting and engraving machine , laser marking machine , if you need any help in the further welcome to contact us !
    Whatsapp : +86 15919906646
    Email : support@triumphlaser.com
    Best regards
    David
    Mar 2008
    Did you check the optics?
    Oct 2016
    Coral Springs
    Quote Originally Posted by warrenb View Post
    Yes I sure did. I just found that one of the fans are not working on the power supply just ordered two new ones. Maybe the unit is running hot ?
    Mike
