I am hoping someone on here can help me with an issue.
My machine is running RDWorks V8
Two days ago it stopped homing the x axis on startup - Home is up and right. Instead it would go up and them crawl to the lefte for about 2 mins then speed to the left and crash into the end (opposite side to the proximity sensor).
I purchased a new sensor and installed it, this has got me to the current situation.
Old Sensor
Diagnostics - XLimit - : Showing Green no matter where the head is When X Home Enabled - Laser Head - creeping to the left then speeding up and hitting left side. Lamp 1 on Controller LmtX- : Always on Steel Blade placed on top of sensor - LED on sensor Lights
New Sensor
Diagnostics - XLimit - : Does not light no matter where the head is When X Home Enabled - Laser Head - move to right and hits side. Lamp 1 on Controller LmtX- : Never lights Steel Blade placed on top of sensor - LED on sensor Lights X Value on display when head moved to home reads X:1000 Y:0
