Need help with laser driver and TTL signal - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Need help with laser driver and TTL signal
  1. #21
    Dec 2008
    Default Re: Need help with laser driver and TTL signal
    Quote Originally Posted by biqut2 View Post
    Thanks for the fast reply.That pretty much reflects how I have mine hooked up. I've sorted everything out except for when I issue an S command there is a momentary pause that leaves a dot on my engraved lines. I've turned off spindle delays, turned of backlash compensation, turned up acceleration to ridiculouslyhigh levels and can't seen to get rid of this little pause. I am using the spindle speed/PWM to vary th laser power which works fine except for the pause. If you have any idea whats cauing this youd be saving me much banging of my head against the wall.
    Can you post a small section of code?
  2. #22
    Nov 2009
    Here is the beginning of one test program:
    G90
    G0 X0 Y0
    M3 S0
    F1000
    G91
    S0
    G0 X0 Y0.333 S0
    G1 X.333 Y-.333 S20
    S0
    G0 X0.333 Y0 S0
    G1 X-.667 Y.667 S20
    S0
    G0 X0 Y0.333 S0
    G1 X.333 Y-.333 S20
    X.667 Y-.667 S21
    S0
    G0 X0.333 Y0 S0
    G1 X-.667 Y.667 S22
    X-.667 Y.667 S21
    S0
    G0 X0 Y0.333 S0
    G1 X.667 Y-.667 S21
    X1 Y-1 S22
    S0
    Here is another that I tried:
    G01X0Y0
    S0
    M3
    F1500
    S15 G2 R5 X10
    G2 R5 X0
    S0
    M5
    M30
    The first one is code generated from a laser engraving program, the second was just written by hand to burn a circle. The first one just burns the crap out of everything because of the pauses, the second one burns dot where the circle ends.
  3. #23
    Dec 2008
    Code should work. Sorry I can’t think of anything else now. I have a friend with a similar system and he too is running into some timing issues, a little different from you but still annoying . At some point we may try to put a scope on the signals to see if we can detect a delay, but for now, I too am stumped.
  4. #24
    Nov 2009
    Quote Originally Posted by BRobbins View Post
    Ah well, thank you very much for taking a look.
  5. #25
    Nov 2009
    If anyone else stumbles upon this thread like I did looking for answers I've found a solution. It's late and I'll try to post the code and details tomorrow. Still working on processing raster images through mach3 though. That's going to take a little postprocessor magic.
  6. #26
    Member torkcm's Avatar
    Nov 2019
    I am in the process of setting up a similar laser with mach3 and a G540 controller, what was the solution? I know this is a few years back but hoping to find out what was the issue.
