Need Help! Circles not round, 6040 laser machine - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 25 to 36 of 52
Thread: Circles not round, 6040 laser machine
  1. #25
    Jul 2011
    Argentina
    Default Re: Circles not round, 6040 laser machine
    Before, I will try a bigger square, a lot more than 10x10 cmts...
    Martin.-
  2. #26
    Dec 2014
    Quote Originally Posted by otromar View Post
    Hi, to discard errors of one axis in the controller, can you invert the conections between controller and drivers ? (with all the precautions about homing, distances of x and y etc)
    Just thinking
    Martin.-
    it´s curious because that's the next idea i had planned haha, will try and report back
  3. #27
    Dec 2014
    Quote Originally Posted by Christian_S View Post
    The normal method of measuring backlash is to use a dial or test indicator like this. If you don't have a suitable indicator some cruder method can be devised, or you can just try adding a little bit of compensation and experiment.
    hum... out of ideas regarding the way to test it, any crude method leaves me without knowing if i have wrong steps per pulse or if i have backlash :/
  4. #28
    Registered KOC62's Avatar
    Mar 2009
    Quote Originally Posted by tigox View Post
    What I suggested earlier would tell you if the steps per units are correct. That is, you take a tape measure and using as much length of your axis, command the X-axis to move the distance.
    You can adjust the pulses per unit steps to match the distance. The longer your distance the less error due to "eye-balling" the start-end marks.
    Do the same for the other axis. Since the movement is in one direction, the backlash will be a very small percentage of error over the long length of your measurement.
    Backlash is perhaps better sensed if you manually rotate the motor shaft so that you can perceive the amount of motor shaft rotation with no movement of the axis. This will be small.
  5. #29
    Jan 2016
    Norway
    The solution is to measure the difference between "inside" and "outside" features in line with the axis, that are programmed to be cut out with identical size/distance. As the absolute size of the features should be the same, the difference can normally be attributed to backlash. The exception is if your axis response is non-linear to the instructed position, this can be checked by measuring if there is any difference between identical features cut at different positions along the axis. I have sketched an example of cut outs you can do to measure backlash this way:
    If you follow this method the backlash on the axis parallel to the cutouts will be the difference divided by four ((y1 - y2)/4).
    Edit: The sketch is in millimeters, but the sizes are not critical other than enabling easy measurement with a caliper.
    Attached Thumbnails Attached Thumbnails Circles not round,  6040 laser machine-20160420-png
  6. #30
    Dec 2014
    Today I made many... MANY tests, and noticed some interesting things.
    Firstly I tried switching the X axis for the y axis aaand the circle came out mirrored which is... Interesting?
    Tried changing the microstepping and nothing.
    Tried changing the current on the X axis which interesting enough is half of the y axis?
    Tried many squares and circles and came to the conclusion that above a certain size the circles seem to come out straight.
    Tried screwing all screws.
    Etc etc... I tried many things today and don't know what to think of the results, if anyone has any idea of what this tells me, I would be grateful, especially the circles coming out oval but mirrored when I exchanged the connectors on the stepper drivers.
    I'll attach all tests I made today, and be aware that rectangles and alongated things are due to me having different steps at one point causing one of the axis to go a greater distance.
    ALSO, I noticed a 0.2mm difference between the X and y axis when I made a square. The y axis cut was 0.2 mm shorter than the X axis, but I don't think this would cause such an irregular circles especially diagonal errors like what's happening.
    Attached Thumbnails Attached Thumbnails Circles not round,  6040 laser machine-img_20160420_204042-jpg   Circles not round,  6040 laser machine-img_20160420_204039-jpg   Circles not round,  6040 laser machine-img_20160420_204029-jpg   Circles not round,  6040 laser machine-img_20160420_204025-jpg
  7. #31
    Aug 2015
    Hi Tigox,
    I just posted a similar issue here: http://www.cnczone.com/forums/genera...ml#post1871682
    If I can fix my problem (or vice versa), perhaps we can help each other out.
    Thanks,
    Mike
  8. #32
    Jul 2011
    Argentina
    i wrote without read carefully. edited
    Martin.-
  9. #33
    Jul 2011
    Argentina
    I wrote something but is wrong.
    I ask you, when you invert the axis and say mirrored, mean ... rotated 90° ? if is rotated 90° then i think this is not a problem to the axis, is a problem of software or controller...
    Martin.-
  10. #34
    Dec 2014
    Quote Originally Posted by trdcelica View Post
    Hi Tigox,
    Thanks,
    Mike
    of course!
  11. #35
    Dec 2014
    Martin.-
    by mirrored i mean mirrored on the y axis, for example, if you made a circle on an acrylic piece and then flipped the acrylic piece to its back you would observe the same effect
  12. #36
    Dec 2014
    Pics of what's happening.
    Left is after switching wires between x and y and right is normal state of the machine
    Attached Thumbnails Attached Thumbnails Circles not round,  6040 laser machine-img-20160421-wa0004-jpg
