Need Help! Circles not round, 6040 laser machine - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 13 to 24 of 52
Thread: Circles not round, 6040 laser machine
  1. #13
    Dec 2014
    Default Re: Circles not round, 6040 laser machine
    all suggestions the manufacturer gives me are software based as most chinese manufacturers...
    i hope it's not a physical problem with the machine... do i even stand a chance in fixing this? the oval shape is noticeable on smaller circles and as you go bigger it becomes less noticeable, wouldn't it be the other way around if it was a physical problem?
  2. #14
    Registered KOC62's Avatar
    Mar 2009
    Quote Originally Posted by tigox View Post
    i have tried about 10cm (4 inches) and it was short by about half a millimeter ( about 0.019685 inches), and this happened on both axis ( not surprisingly since they have the same steps per pulse unit) thus that doesn't seem to be the problem because it would not show as much on such small circles.... :/
    That's good.
    I'm trying to eliminate the calibration as a source of error.
    The next thing I would want to know if making a circle real slow also causes an error. In other words, is the error affected by speed? Or feedrate/acceleration/inertia... type issues.
    Is there a some flex in the X / Y axes that might cause this error?
  3. #15
    Dec 2014
    Quote Originally Posted by KOC62 View Post
    That's good.
    Changing speed or acceleration makes no difference at all, which tells me that it's not caused by flex? I think...
  4. #16
    Mar 2009
    If it is really not mechanical (including back-lash), then one would look at the software, including configuration settings, side for possible errors.
    Your circles, or rectangles, g-code looks good on the monitor?
  5. #17
    Dec 2014
    I don't think the problem is backlash because the problem happens no matter the speed or acceleration.
    Lasercut doesn't show gcode.
  6. #18
    Registered javanree's Avatar
    Jul 2011
    Netherlands
    Have you tried different software then? Mach3 (which usually is shipped with the 6040 machines) or perhaps LinuxCNC?
  7. #19
    Apr 2016
    have you try to reduce speed ?
  8. #20
    Dec 2014
    Quote Originally Posted by javanree View Post
    Didn't know Mach3 or linuxcnc worked with mpc6585, would not mind trying if so.
    - - - Updated - - -
    Quote Originally Posted by philippelang View Post
    Yes both high and low (and veeery low speed haha)
  9. #21
    Jan 2016
    Norway
    It looks to me like simple mechanical backlash, on both axises. Since backlash is most noticeable when changing direction on each axis with backlash, it does fit with the squarelike circles seen in your pictures, since direction changes where the circle is perpendicular to the axises. (The circles may look oval because the diameter is reduced in the axis directions.) Backlash could also explain why it is more visible for smaller circles, since the deflection would be larger in relation to the circle diameter. Excessive backlash can also cause straightness error in movements perpendicular to the axis with backlash.
    As you have mentioned tightening the belts, I would try backlash compensation in software if that is an option, and also to try cutting any straight lines at an angle to the machine axises. If this does not help I would probably start looking for a mechanical upgrade.
  10. #22
    Dec 2014
    Quote Originally Posted by Christian_S View Post
    How might I go about testing backlash? Lasercut does in fact have backlash compensation
  11. #23
    Jan 2016
    Norway
    The normal method of measuring backlash is to use a dial or test indicator like this. If you don't have a suitable indicator some cruder method can be devised, or you can just try adding a little bit of compensation and experiment.
  12. #24
    Jul 2011
    Argentina
    Hi, to discard errors of one axis in the controller, can you invert the conections between controller and drivers ? (with all the precautions about homing, distances of x and y etc)
    Just thinking
    Martin.-
