If you could provide some close up pictures especially around the edges of the board it might help pinpoint your issue as well. Especially were power enters the board. Thanks
Russ
I will check ground and verify part number ! Thanks a lot!
Enviado do meu iPad usando Tapatalk
Russ
Russ,
pictures....
OK, we have more things going on board and will probably need a few more pictures.
First here is what we know now that I can see many of the devices.
The AZ1085S-3.3 is actually a 3.3 volt regulator they make one just like this that is 5V but this one is 3.3V look at the spec sheet uploaded and you can verify the pinouts. I think that one is working based on your previous readings.
The AMS1117-1.8 is actually a 1.8 volt regulator and based on one of your other readings that might be working but I will upload the spec sheet for pinout info and you can measure the voltages.
We need close shots of any part that has 3 to 5 legs and looks similar to these two parts. The 5V input to the larger AZ1085S-3.3 comes from somewhere and that output must also be good or these voltages would not show on the input of the regulator.
Russ
We probably need to back up a little bit. I just downloaded your manual and if you look on page 24,25 there are eight LEDS on the control board that can generate error codes, can you check those and let us know which ones are on... Think they are labeled D1 to D8, they are shown in the manual on page 8.
Russ
Russ, i will verify better but they dont seem strange. When machine is doing datum the two leds of motors x an y are on. But since motor is not moving they are fixed on until i hit stop on the contol pannel and get acess to the menus...then they get off. But i will check better tomorow if i can get to shop because of the olimpics games.... Thanks a lot for the help russ !!
Enjoy the excitement the games bring. I have not been to Sao Paulo or Campinis in over ten years. Yeah check the LEDs and see if it gives us a clue. I. Watched your video and saw lots of flashing LEDs which says much of the controller is working
Russ
Здравствуйте. У меня та же проблема.
?????????: ??? ?????? ???? ??? ?? 4-? 74act14 (??????? ? ??????)- ?????? ????????? ???????, ???? ?? ????. ????? ?????? tlc5615- ???????? ? ???.
