Chinese laser 50W, 50x30cm - bad/good stuff, mods, problems etc. - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 61 to 62 of 62
Thread: Chinese laser 50W, 50x30cm - bad/good stuff, mods, problems etc.
  1. #61
    May 2015
    Greece
    Default Re: Chinese laser 50W, 50x30cm - bad/good stuff, mods, problems etc.
    Hello cnczone members!
    I have an issue with my laser cnc 50 w chinese cutter.
    I don't have clear cut. The cutting line is not smooth. I attached a photo with the problem. Has another member this issue?
    Thank you!!Chinese laser 50W, 50x30cm - bad/good stuff, mods, problems etc.-30020421_10216514827293040_952559385_n-jpg
    Attached Thumbnails Attached Thumbnails Chinese laser 50W, 50x30cm - bad/good stuff, mods, problems etc.-30020421_10216514827293040_952559385_n-jpg
  2. #62
    Jan 2017
    Quote Originally Posted by TehPepper View Post
    LED 14 is always blinking on mine. I do believe the slow ~1.5 second blinking is the normal running state on the RDC644 controller.
    My first PSU failed after about 3 hours. After some arguing I got a replacement and then repaired the original so I have a spare. In my case it was the switch mode controller that dropped it guts out the bottom of the package.
    Symptoms of that failure was the laser PSU was totally dead. No fan, no power LED, no laser
    What is your laser PSU doing in the failed state?
    Can you share with us what model Laser power supply you have?
    Have you got an ammeter installed?
    I have not put that many hours (maybe about 40) on my machine in the two years I have had it. As they come they are hobby grade, hence the hobby price. I'm sure with a better laser tube, power supply and a few tweaks like an ammeter they might do ok but I personally would not use this machine to run a business unless I had a garage full of them and some spares.
    I guess at two you have made a start
    I own 3 of these machines for that reason. I only get 9 months of use before I change the power supply and tube. I always replace both at the same time. This has extended the life of mine.
