Before you start repairing first check if the laser still works at all.
Move the ring slightly away from laser path and make short test.
2-3 seconds test laser will survive without problem.
60w ebay laser tube glass ring was unglued when it arrived, tube was installed already. Does anyone know what glue to use to glue it back. I'm new to all this, my first laser. Also the spot weld next to the lid upon opening 2 times broke where the air shock is mounted. I will beef this area up from underneath.
CNC lasers, constructions, service
Ok I just tested the laser and it works, so now what would be the best way to go about it to glue it back?
Ok, I'll keep looking. If anyone has done this please let me know how you did it, thanks
I would start looking for glue :-)
what epoxy did you use? I tried epoxy for glass bit it still detaches it.
I dont know if jb welder is going to be a good idea.
