I think you need to fiddle with the settings, first select correct main board.. this probably will solve most of your problems. You need to also set the platform size in the settings. The settings in the corel laser plugin are not set for your machine, and need to be set manually.
These settings can be found from the configuration in corel-laser plugin.
