Need Help! Laser machine disconnects continuously from pc
Results 1 to 8 of 8
Thread: Laser machine disconnects continuously from pc
    May 2015
    India
    Default Laser machine disconnects continuously from pc
    Hello Everyone,
    I bought a chinese 50w laser engraver and cutter 3 months back. It got corel laser and laserdrw softwares. corellaser didnt work and I was working with laser draw software. It worked fine before but now while engraving the machine is disconnecting and connecting continuously. Sometimes the machine stops and starts again after 3 seconds. Iam getting the message " Engraving machine is disconnected -
    1. If the machine is not powered, Please power on
    2. If the machine is offline, reconnect it
    3. If prepare to cancel current task, please click [cancel]. Error Id : 0 "
    Iam getting this message only when I set high current for cutting acrylic. It gives a laser firing sound and then it stops cutting but the laser nozzle moves around without cutting. Iam setting current regulation 8 (I think it is mA. Iam not sure as Iam new to CNC and laser cutting) while engraving and while cutting 10 and keep the speed 2mm/s. If I go beyond 10, then the machine disconnects.
    The information which I found on the machine
    mainboard: 6C6879-LASER-M2
    device id: 492B4D1F3D015F57
    Could anyone help me solve this issue ?
    Attached Thumbnails Attached Thumbnails Laser machine disconnects continuously from pc-laser-machine-error-message-jpg
    Jan 2008
    Default Re: Laser machine disconnects continuously from pc
    What brand computer are you using. On my CNC if I try to use a Dell it will do that
    May 2015
    India
    Iam using Lenovo I7 Laptop (RAM 12 GB). This disconnectivity problem happens only for past few days. In the beginning it worked well.
    May 2016
    to solve this problem? I has the same order?
    Mar 2016
    Chile
    Quote Originally Posted by Jeffmartin View Post
    Hello Everyone,
    Same problem ¡¡¡ solution???
    Sep 2005
    The design downloads to the machine and its memory. Once that is done you can usually disconnect the USB cable and run everything from the machine keypad without your computer. Just guessing as it only happens on full power to the tube you have power supply issues. On my Chinese machine I had loose connections and had to check and re-tighten,
    Did you contact the people you purchased from?
    Retired Master Electrician, HVAC/R Commercial union shop and Lots of hobbies. FLA Saturn 2 4x4 CNC Router
  7. #7
    Registered Paul-Anternson's Avatar
    Dec 2015
    the problem is caused by the main board, the current will affect its stability while working.
  8. #8
    *Registered User* mendimi's Avatar
    Nov 2018
    Hello.the same problem i have with my china Laser.I don`t think even is mother board problem.i tested it with new motherboard and usb dongle from new machine not works.
    I checked all wires with multimeter and all of them are fine.Motors move when i power the laser.
    The corel laser driver always say engraving laser is disconnected
    Hope here i will find a fix
