Parameter password reset
Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Parameter password reset
    Apr 2015
    Default Parameter password reset
    Does anyone know what the password would be on the chinese engravers to reset the parameters to the default settings?
    Jun 2014
    China
    Default Re: Parameter password reset
    Hello, which controller do you use? different controller has different password. our machine use RDC6442G controller.
    How to use laser software - Thunderlaser
    E-mail:nolan@thunderlaser.com facebook:https://www.facebook.com/ThunderLaser
    Facebook Laser Cutter Tech Support: https://www.facebook.com/groups/lasercuttertechsupport
    Apr 2015
    Quote Originally Posted by Nolan Yang View Post
    Hello Nolan. That is the same controller that we use as well.
    Jun 2014
    China
    the password is rd8888, please have a try.
    Apr 2015
    We tried that password and it did not work.
    Jun 2014
    China
    Hello Stephanie, have you solved this problems? sorry for the late reply, I just come back from holidays. please try HF8888.
  7. #7
    Mar 2013
    Hello Nolan, HF8888 does work for factory default, thank you (I am also using the RDC6442G)! Unfortunately it messed up my y-axis. I was having problem with my PWM set incorrectly for laser control, is there a separate password for factory parameters to fix both my Y-axis issue now and the PWM? (HF8888 and RD8888 do not work for fact para)
  8. #8
    Jun 2014
    China
    you can try CC8888
  9. #9
    Mar 2013
    Hi Nolan, that password worked thank you!
  10. #10
    Mar 2013
    Nolan, one last question, I have greatly appreciated you help. Is there a vendor default for baseline redsail style machines using the RDC6442G controller? As seen in the thread:
    http://www.cnczone.com/forums/genera...-software.html
    With the images of:
    Parameter password reset-y-axis-1-jpgParameter password reset-x-axis-jpgParameter password reset-laser-jpg
    Is there information available for the Manufacturer Settings, ie the file, or just the numbers?
    Thank you so much!
    Doug
  11. #11
    Jun 2014
    China
    Hello Cogolith, every company has different setting, so I don't know vendor default for your baseline redsail machine, you should ask your supplier for help.
  12. #12
    May 2015
    Russia
    Hello Nolan, I was having problem with RDC6442G controller. When the controller is started, the LED 13 on the controller lights up, and on the display there is an image "Connecting to controller...".
    Further the controller isn't loaded. How it is possible to solve this problem?
