Here is the result .... well it works and it doesn't works.
I explain myself, I connected the P-(k+ on the old power supply) from the control panel on the H of the power supply, and the P of the power supply has been connected to the ground.
Here is what's happening: when I connect the cable to the ground the laser works without pressing any button, and it stop if I stop the connection(I was holding myself the cable and made it touch the ground).
