EDIT:
I've just realised something, P+ and ground were sold together on the old supply ,If I understood well, the P+ must be rely on a security(like a end stop on the lid) and to the ground, so ,for example if you open the lid of the engraver, the laser will stop !!??
And as you wrote me before the K+ will have to be rely on the H connector on the new power supply. So if i'm connecting the P+ tyo the ground and the P(P- on the control panel that was rely to the K+ on the old power supply) to the H on the new connector , do you think it will works without problems(I explosion, fire or else !!
Later I will put a security button, not to prevent the opening of the engraver but on the water pump
