I want to import a file i created with illustrator into 'lasercutengrave' what looks like an simplified version of lasercut 5,3. When i save it as illustrator V3, i get an image in lasercutengrave but it is weird and with several objects connected with lines like (see screenshots)
Original Illustrator file.
Imported as v3 .ai in lasercutengrave v3.3
When i save als illustrator v8 i only get a rectangle box and no objects in it.
When i save as .dxf in any version i only get a rectangle box with no objects.
The past file's i have put trough corel draw to save as dxf but i've used illustrator for years and can't adapt to corel quite easily.
But i now have a problem with this illustration, i would like to engrave the box around 'henry ford' but the letters not engraved.
Saved as .ai, opened in corel draw, then saved as .dxf, then opened in lasercutengrave:
It engrave's the box completely, it doens't leave the letters untouched.
I now hope it is possible with lasercut 5,3. But does this software works with my controller (ls240-a)?
My controller:
Can someone please look if it is possible to import my illustrator file into lasercut 5,3 so i can buy this piece of software/dongle.
Link:
https://drive.google.com/open?id=0B8...d00&authuser=1
I am frustrated with this process from illustrator trough lasercutengrave, hope lasercut will be beter, if not, what controller would be a easy upgrade with better software?
Thanks for your time!
