From what I've read also its just that the 500's fail and the 52 is much more reliable. Maybe someone else has a better explanation but if it fail why take a chance get the more reliable one. you get what you pay for so they say.
I read hear that there are flaws with the CW5000 but can't find what exactly they are.
Would someone care to comment on what the advantages are to having the 5200 over the 5000. This will be for a Reci W2 / 80W but it does get very hot where I live and will be working in low humidy high temp environment in the Summer, even up to 30 - 40 C.
Thanks!
normally , w2 80w reci laser tube ,more people choose cw-3000 water chiller ,of course cw-5200 is better solution , for high tempeture area , 5200 is essential ,but for 5000 only a little change with 5200, you should check if the water chiller ,maybe there is something wrong with you chiller .
Hello ,Bill
You can visit the website to know more about the Water Chiller
Water Chiller Instructions
If you have any thing unclear ,just feel free to ask me
- - - Updated - - -
Hello ,Bill
http://www.thunderlaser.com/products/laser-accessories/206-water-chiller-instructions.html
I do not know much about CW5000/5200 but I have got one(DWT-8PSA model) from Water Cooler with Water Tank | DERYUN PRECISE INDUSTRIES CO., LTD. | Product Information
It cools down two 140W tubes very well. Even for 30 minutes job water temperature stays within 2 degrees range. I set it to cool down if water goes higher than 18 degrees C and it does the job. And recently when it was +37 C in my shop water temperature was within 18-20 C all the time my laser was on.
CW3000 is rated to 50 watts (it isn't a chiller, its a fan and a copper coil)
The CW5000 has a dissimilar metal joint in the cooling gas coil that can lead to gas leakage, great but there is no way to refill them if they do vent the gas out unless you add an ancilliary port. The pump on the 5000 is also rather small considering the work it has to do.
5200 is a fine piece of kit.
cheers
Dave
BadBoy,
We have shipped over 400 CW500's with our lasers and maybe had warranty issues with 2 or 3 at the most. Some are working in makerplaces at 10+ hours a day and others in Phoenix garages etc.
Let me know if we can help in any other way.
John
How about we tape a $100 Wally World 5000 BTU air conditioner to a CW3000 chiller? Now it's a 5000 BTU chiller.(1466 watts) How many BTU's is the CW 5000?
Adrian
S&A company specializes in producing industrial water chillers for more than 12 years , S&A chiller series include:CW-3000,CW-5000,CW-5200,Email: marketing@teyuchiller.com
Hello all I am new on the forums and had a question and do not see where to add a new post, maybe because I just joined. I have been running a Chinese 40 Watt laser for about 6 months I was told to use RV antifreeze for coolant. I have just purchased a new 80 Watt Chinese CNC laser machine and the CW5200 chiller. My question is should I use the same RV (pink) antifreeze with the chiller or do I just use plain water? I believe one of the reason to use antifreeze was to keep anything from growing in it. If anyone could help me out that would be great. Thanks for any information.
Frank Jones
Hi, you has pictures of this good idea A/C + CW3000 = 5000 BTU Chiller, NICE!
I just purchased the S&A 5000 and cannot find out how to connect the alarm to the 60w red/black laser I also just bought. Any information would be great.
