new prototyping software
Results 1 to 5 of 5
Thread: new prototyping software
    Registered cncadmin's Avatar
    Mar 2003
    Default new prototyping software
    Worth a mention-
    Turn complex 3 or 4 axis jobs into parts in minutes with ProtoWizard. ProtoWizard is driven by 3D STL files generated by any of your favorite CAD systems. Simply import the STL file or files of your design, select a roughing and finishing tool, and in minutes you have the G Code file for any of the most popular CNC Milling machines.
    http://www.excaliburcnc.com/pwmain.html
    online demo- http://www.excaliburcnc.com/pwring_demo.html
    Thank You,
    Paul G
    Check out-
    [URL="http://www.signs101.com"]www.signs101.com[/URL]
    Feb 2007
    Your links don't work. Sorry.
    Mar 2005
    I use DeskProto, same idea, import an .stl generates g code really fast. Has all the features I need and great support by the guy that created it.
    Mar 2013
    Your both links are not working please check and provide the working links if possible. Otherwise you should explain more about this topic. I am interested in this topic.
    Member awerby's Avatar
    Apr 2004
    Protowizard is still around; here's a link to their site: http://www.protowizard.com/
    I prefer DeskProto's system for holding onto rings and other small parts that jewelers cut in wax. It doesn't have any moving parts, so there's no "slop factor"; you simply loosen a screw and fasten the pre-drilled wax blank in another position for further milling. It has an adaptor to work on Sherline's (and Taig's) popular 4" rotary table as well as Roland machines. Here's a link to further information about it: http://www.deskproto.com/products/123waxring.htm
    Andrew Werby
    www.computersculpture.com
