manipulating a STL file
Results 1 to 7 of 7
Thread: manipulating a STL file
    Registered Drools's Avatar
    Feb 2009
    Default manipulating a STL file
    I'm a complete noob when working with STL files. I found a set of chess pieces in stl format however they are vertical and I would like to try and cut them with my 3 axis machine. Can the models be rotated 90 degrees so they lay flat? I can try some double sided routing if this is possible?
    Thank You.
    Mar 2008
    BCS Mexico
    yes.....what software are you using to import?
    Feb 2009
    well thanks to this forum I have a few friends that make my tool paths for me as I'm CAM-less. They use ArtCAM and Aspire to make the tool paths for me. I'm still looking for an affordable package that is easy to learn.
    Thank You.
    Member awerby's Avatar
    Apr 2004
    Take a look at DeskProto. There is a two-side wizard that keeps the part in registration when you flip it over to do the other side. If you've got a rotary fourth axis, it supports that. We offer greatly reduced hobbyist pricing to non-commercial users, and you can download and use it for a month for free.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Feb 2009
    Thanks for the link Andrew, I will have a look at it asap. I do have a lot of experience with double sided PCB creation that is why I was wondering if the stl model could be made to lay flat. I guess the model could be sliced down the middle and then made to lay flat, both sides would be cut to the same relief.
    Thank You.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    The CAM software should let you rotate the model when it's imported.
    UCCNC 2017 Screenset
  7. #7
    Apr 2004
    Yes, just about every CAM software (including DeskProto) has that ability. But if you're cutting something on two sides, you've got to leave a "frame" of material around it that can be registered when it flips over, and some supports that will attach it to the frame. Deskproto will do all that automatically; in other programs you'd do it in your CAD program and provide pins and holes to register the part so the halves match up.
    Andrew Werby
