- Okuma MC 40VA OSP7000M Zero & tool offset
I have a problem with the tool offset to work zero. set the work zero, with one tool. All ok, when I do a tool change & set zero tool offset, the values are not correct. Can't work out why they don't seem right. Have deleted all offset & started again, same problem. It has been some 28-30 years since I program anything. 1 cycle all went great, second op tool change, offset wrong.
- You may not post replies
- You may not edit your posts
Forum Rules
