- Need Help!- Laser fiber engravement
Re: Laser fiber engravement
Easiest solution is to export out of coreldraw as a vector file rather than a PNG. I use DXF, then add a hatch in ezcad.
When you export as PNG the computer breaks the image up into a grid of pixels and the software adjusts the power for the darkness of the pixel. Even white still has some amount of power. You can change this in EZCAD, but you will be much better off if you use a vector. It will be faster and look better.
- You may not post replies
- You may not edit your posts
Forum Rules
