Amazing job! It's not difficult to build co2 laser. But if you have experience to build your own plasma, I think you can do it.
Are you an engineer?
Hello everyone, my name is Allan i am from argentina and i have been building cnc machines for the last 3 years, we build laser co2, plasma and router. I was wondering if it is possible to build a home made fiber laser machine for cutting metal. If i get the head and the source, what else do i need?
I am looking for parts over here:
https://es.aliexpress.com/store/1513...ead_5999282.14
thanks.
It is easier to build a plasma cnc than a co2 laser, i am industrial designer not engineer, there is a lot of information in forums if you want to build machines that i make, but there is nothing about fiber laser
Have you tried to contact cloudray official store for what parts needed ?Read thisHTML Code:https://www.morntech.com/blog/fiber-laser-cutting-machine/8-important-components-of-fiber-laser-cutting-machine/
sorry, read this https://www.morntech.com/blog/fiber-...tting-machine/
Table of Contents
8 Important Components of Fiber Laser Cutting Machine
Core Components of Fiber Laser Cutting Machine
1. Fiber laser source
2. Laser Cutting Head
3. Servo Motors
4. Water Chiller
5. Air Cutting System
6. Host
7. Control system
8. Stabilizer
A fiber cutting machine is a laser cutting equipment that uses a fiber laser generator as a light source. Fiber laser is a new type of fiber laser that is newly developed in the world. It outputs a high-energy-density laser beam, which is concentrated on the surface of the workpiece so that the area irradiated by the ultra-fine focus spot on the workpiece is instantly melted and vaporized, and the spot is moved by the numerical control mechanical system Realize automatic cutting by irradiating position. Check out this page, I hope it helps you: https://forsuncnc.com/fiber-laser-cutter/
Hello. From Ukraine. I will write in Russian. How are you doing with building a cnc laser. I'm trying too. Here is the controller if needed https://aliexpress.ru/i/4000224050170.html I can give more. If needed.What have you built? Sorry for my English.
Ahil
