New Machine Build In need of advice for a used laser source
Results 1 to 2 of 2
Thread: In need of advice for a used laser source
    Member MelNick's Avatar
    May 2016
    Ukraine
    Default In need of advice for a used laser source
    Good day everyone
    I run a small shop making decorations and have always wanted a metal cutting laser as plasma is just not precise enough
    Had some experience with CO² lasers and DIYing various CNC machines
    There's a listing on ebay for a used 500w source so I thought I might turn it into a fun summer project
    In need of advice for a used laser source-image-1-jpg
    Before I waste some money there are questions:
    - is 980nm ok for cutting steel? (most commercial units are 1064nm)
    - is there anything special software-wise or may I treat it as an expensive plasma machine?
    - aside from the source, the optical cable and the head, what other expensive/hard to purchase parts are there?
    Promise to run a build thread if all goes well :-)
    Thanks in advance!
    Attached Thumbnails Attached Thumbnails In need of advice for a used laser source-image-1-jpg
    May 2016
    Ukraine
    Default Re: In need of advice for a used laser source
