Having trouble with 2kw bescutter 12 ga stainless slag
Results 1 to 2 of 2
Thread: Having trouble with 2kw bescutter 12 ga stainless slag
    aklatt1009's Avatar
    Jan 2021
    Default Having trouble with 2kw bescutter 12 ga stainless slag
    I’m getting a lot of slag on 12 ga stainless. Running a 1.0 tip and nitrogen. Any suggestions?
    May 2007
    Default Re: Having trouble with 2kw bescutter 12 ga stainless slag
    1 KW full power (all I have). 150 PSI Nitrogen and .3 MM cut height, zero focus to start. 2 stage pierce and I forget cut speed. Nozzle MUST be clean and centered. My cuts go straight to the press brake, or edge braking/softening.
    Test cut some 75 mm circles, and mark the surface with a sharpie so you can match up the cupon and see if the slag is always on one side. Smaller circles will have you chasing your tail because of accel/decel.
