- trumpf trulaser l3030 fiber
Shortly we have a new laser cutting machine from trumpf. (the l3030 fiber)
Most of the standard setting work well but i have an issue with cutting aluminum diamond plates 2.5/4 and 3/5 mm thick.
wich settings and nozzle do u guys use for these plates.
Greetings Nielske93.
Re: trumpf trulaser l3030 fiber
Are you measuring the thickness of the Diamond and using that tech table? For 1/8" Diamond plate I use the 3/16 tech table. You can also put the sheet on upside down, That some times helps.
- You may not post replies
- You may not edit your posts
Forum Rules
