- Which fiber laser will do this kind of job?
I have access to a 100 watt fiber laser and was wondering if I need something different? If I can use this laser to etch these designs what setting would I need to get down to bare metal and in how many passes? and yes I know that the lasers will be a fraction of the speed of this $100k+ laser and Im fine with that. The metal is Carbon Steel (stainless in some cases) and the coating is just black/iron oxide (which i believe is equivalent to rust). Links below:
https://www.instagram.com/p/BcgObqAD...on_share_sheet
https://www.instagram.com/p/Bf_85eIn...on_share_sheet
- You may not post replies
- You may not edit your posts
Forum Rules
