1 kW Fiber laser machine "without cover"
Results 1 to 4 of 4
Thread: 1 kW Fiber laser machine "without cover"
    cevdet
    Guest
    Exclamation 1 kW Fiber laser machine "without cover"
    Hey guys, is there anyone using 1-kw fiber laser cutting machine "without cover" for metal cutting in Germany?
    I'm working on 6-8 mm stainless steel. Are you recommend to me?
    May 2016
    Default Re: 1 kW Fiber laser machine "without cover"
    I see nobody answered this question. Yes I have been using one fiber laser cutting machine of 1KW power for 2 years now. Can cut up to 10mm Mild steel. 1 Kw power cannot cut 6mm of staniless. The maximum you can cut in ss is 5mm
    Member CeliaB's Avatar
    Dec 2018
    Hello, do you need a 1kw laser machine without cover in Germany?
    May 2016
    Quote Originally Posted by CeliaB View Post
    Yes, if you have one in good conditions please send me specs
