- Need Help!- 1990 Leblond Makino EDNC-32
Trying to get an EDNC-32 running I picked up at an auction earlier this year. Has MGC3 control. First thing after getting it wired up and filled with fluid was touch isn't working and now I have an emergency stop alarm. Happened I think, and it might have just been a coincidence, when I was pulling the head cover off to see if there was any wire off causing the touch not to work. There is nothing I could see as far as any wire that might have been pulled out from just removing the cover. I've had this cover off before to fix the z axis travel dial. I'm sure there's limited knowledge about this old of a machine.
- You may not post replies
- You may not edit your posts
Forum Rules
