- Charmilles Roboform 30 Don't charge the Communication file
Hi
I have a Problem with my roboform 30 Charmilles, we move all my machines to other warehouse. and we install my charmilles roboform 30. we I try to load the disk A (communication software) the machine detect the disk and begin to load the COM.BX8 file, but in around 60% o 65% of the loading proccess the machines return to the option selection screen without complete the proccess.
when I select load again, beagin to load from 0% again, and we take off the Disk 1 and insert the disk 2 (PIL. BX8 and EXE.BX8) start to load this files bur in COM file status the machine write this message : "CHECKSUM"
when the disk B is loaded the machine don't startup the system.
I don't know what is happening here. If you can you can help me I will appreciate that.
I try to load the communication file with other 3 disk (copy) and It do the same thing.
- You may not post replies
- You may not edit your posts
Forum Rules
