- Edge find issue (Robocut Alpha 1b)
Re: Edge find issue (Robocut Alpha 1b)
This workpiece onthe picture looks very bad. Is it cast iron? If it is it's covered with oxidation on the outside and it's non conductive too.
Edgr of the hole also looks quite rusty, and it definitelly doesn't help. While edge finding there is very low voltage between wire and table so surfaces needs to be clean for proper action.
About fast rusting U may consider replacing ion exchange resin, or at least flush it wit air stream for now. Low eficiency of ion exchange makes corrosion faster.
It's 4140.. It looks like that from the wire work I was able to do before this issue came up.. I've cleaned up the edges I'm trying to pick up (with a dremel).. The guys who made the part on the lathe before I got it are not happy about the rust/corrosion at all..
No one else? Still haven't been able to make progress on this problem.. Suggestions from Methods Machine hasn't helped either.. :-(
Did U try to search edges on some other part?
Yeah, I tried that as well. Same thing..
There is no any magic. If wires and energy blocks are ok. Table is clean and wire feed and tension is on it has to find contact.
U can chceck if there is short circuit sensing between wire and table by lamp on the keyboard.
And of course U can find missing contact between terminals behind keyboard - power wires - table- work wire- guides- power wires - terminals.
There must be some hole.
Thanks for the help Steryd, I'm not sure what was (and probably still is) going on, but the machine decided to cooperate again and is working... Gunna keep digging but got to make parts :-)
- You may not post replies
- You may not edit your posts
Forum Rules
