- Need help CMER 434Z
Need help CMER 434Z
I have in use EDM CHMER 434Z.
This machine has 100 fixed operating modes (so called S codes)
According to the manufacturer, for almost every treatment case, you can find and select the appropriate mode.
Each mode has 9 parameters, including the height and speed of periodic lifting of the electrode for flushing.
In all 100 modes, the lift height does not exceed 2 mm. At the same time, my specificity is such that I need a higher lift.
Can anyone suggest how to edit this S code or set the processing parameters manually?
- You may not post replies
- You may not edit your posts
Forum Rules
