- EDM machine - working table doesnt move
Hello,
I have a wire cutting machine (FANUC TAPE CUT MODEL I, MATRA: 945 Series: 6m system).
The machine was purchased a long time ago in Germany, with no technical documentation supported.
The machine was working great for many years without experiencing any big issues. Now, I have a problem that I am not able to fix.
Here is the scenario:
- When the machine is in auto mode, the working table doesn’t move.
- When I say auto mode, I set a switch from JOG to MEMORY mode, enable all conditions (wire, tension, power, water), and press the START connector. After pressing START connectors on the screen the working desk is not moving and the positions of the X and Y axis are not moving as well.
- Also, I am not able to send the machine in a reference point in auto mode, in manual yes.
When I run the machine in the Manual mode, “set switch to JOG” – I am able to move the working desk. X and Y coordinates are working.
Any information would be very useful.
Thanks,
Re: EDM machine - working table doesnt move
I have similar machine (W2). I had similar problem.
Possible solution:
The machine have addition safty switches: workspace cover and cover of cabin of waste wire .
I can take pictures if you don't find.
Thank you for your reply. I am looking at it but the only switch I see is for changing parameters.
Do you mind to take a picture please, it may solve my problem too.
Thanks in advance,
Dzenad
Hi Elek,
Thank you for the image. Unfortunately, I am not able to find the switch. I don't have machine documentation as well and not able to find what parameter to change.
Please check the link where I uploaded few images. https://drive.google.com/drive/folde...ZC?usp=sharing
On the machine, there is a stamp Fanuc Matra Tape Cut model I. I guess It is the first model of this kind. After you see images, maybe you can navigate me. I think we have the same problems.
If the machine is moving in Manual mode, by pressing X and Y connectors I think electrical motors are in function. What is your opinion?
Regards,
Hi Dzenad,
I compared the parameters of my machines. I have machine book to all together (Fanuc W2 and T3). I dont know, what mean are the below parameters (in the machine book not mention), but these are different. Please, try the change step by step.
P0023: 10000000
P0024: 01000010
I wait for feedback.
Good luck!
Hi Elek, thanks a lot for the instructions.
Unfortunately, we are not able to solve the issue. I was checking those parameters as well but no luck
It is very unusual, as the machine table is moving in manual mode. When in automatic mode, it stops without any warning or error being displayed.
Is there anything else you have in mind I can try?
Hi Dzenad,
if you are in the "auto-mode": can you run program and moving by "dry-run"?
Elek
Hi Elek,
When the machine is in Auto mode, I cannot run the program with DRY RUN. When I enter that process, after clicking START, the machine just doesn't move the table.
In Manual mode, when the switch is in JOG mode I can move the table manually by pressing the X and Y axis.
Hi Dzenad,
this is bad news.
I have no idea now, I am consulting with colleagues (Fanuc fans) in Hungary (whom I know).
Rtegards, Elek.
I tested my W2 machine: it is with switch (cover) controlled. Mean is: if I want to start cutting without cover the machine dosen't move. At the paralell I want to start by dry-run (and without cover), then the machine moving. It is a big different on your situation!
Unfortunately I haven't got any idea for issue.
If you want I can scann my parameter from book but it is different for your machine....
- You may not post replies
- You may not edit your posts
Forum Rules
