Charmilles Robofil 400 disk format error
Results 1 to 3 of 3
Thread: Charmilles Robofil 400 disk format error
    Member nour4151's Avatar
    Jul 2021
    Default Charmilles Robofil 400 disk format error
    Dear EDM users,
    I have an old Charmilles Robofil 400 machine. I have a problem. The machine was not used for a long time, and does not start. I try to reinstall the system from disk but don't work.
    I rehearsed these steps:
    1. I switch on to main power
    2. pushed continuously the button load floppy try to load
    but I come this error message: Loading # CKS error format
    I try to change floppy to same type but don't work nothing, like this can be excluded the mistake of the floppy.
    What may be the problem, hardware, eprom, floppy cable?
    Please help,
    Thanks your attention.
    Best Regards,
    Member Edmrepair's Avatar
    Aug 2021
    Default Re: Charmilles Robofil 400 disk format error
    Disk drive or disk.
    The machine is not getting the exact amount of bits the Data the eprom says it should get
    Maybe bad area at end of disk read
    We repair these machines daily
    We can help with any charmilles edms
    Greatlakeswirerepair@gmail.com
    Sent from my SM-G975U using Tapatalk
    Aug 2021
    Sometimes I use the old diag disk to prove the drive works or not bc the diag disk is usually in great condition and if that works then you know you just need a new software disk
    Justin purdun
