Charmilles Robofil 290 Wire Broken
Results 1 to 2 of 2
Thread: Charmilles Robofil 290 Wire Broken
    luismhp's Avatar
    Dec 2018
    Default Charmilles Robofil 290 Wire Broken
    Hi everyone. I´m coming here hopping to get some help with my EDM machine.
    I can´t cut anything, because an 648 error in my machine, the message is clear: "Wire Broken" ... is not!.
    According with the maintenance manual, the machine detect a innusual speed on the pulley witch control de wire break. it says that the solution in re calibrate the wire using the "Wire Setup" option.
    When i try to do that, all the options in the Wire setup screen are disable.
    Any suggestion? Thank you in advance.
    Member Edmrepair's Avatar
    Aug 2021
    Default Re: Charmilles Robofil 290 Wire Broken
    Are you still having issues the machine
    Has sensed a slip on the encoder up top
    Greatlakeswirerepair@gmail.com
    Sent from my SM-G975U using Tapatalk
