- Solved 2 stage hole pick up?
I'd like to automate within a program, picking up the I.D. of hole twice, once along the axis in the x and y, and the second with the movement axis rotated 45 degrees from the first, finally, then moving to half way point between the two center points and zeroing the work coordinate and making the cut. It's Makino U3 and Mastercam.
- You may not post replies
- You may not edit your posts
Forum Rules
