- Need Help!- filler pump moror problem
we have a sodick A280l wire edm. the main bearing on the filler pump motor seized while the machine was cutting a part. we rebuilt and replaced the motor but it does not start. Is there a reset or fuse or overload somewhere in the control panel?
Re: filler pump moror problem
Did you figure this problem out? I am having the same issue.
- You may not post replies
- You may not edit your posts
Forum Rules
