Need Help! Fanuc Robocut alpha oc wire edm backlash compansation
Results 1 to 9 of 9
Thread: Fanuc Robocut alpha oc wire edm backlash compansation
    May 2007
    Egypt
    Default Fanuc Robocut alpha oc wire edm backlash compansation
    I have fanuc Robocut alpha OC wire EDM having fanuc Series 16-W control. I need to know
    1. How to enable & disable parameter write.
    2. Which parameters are for Axis backlash adjustment.
    Attached Thumbnails Attached Thumbnails Fanuc Robocut alpha oc wire edm backlash compansation-img_20190127_123122-jpg
    Member Sdperkins's Avatar
    Oct 2019
    Quote Originally Posted by shabbirabbas View Post
    Press the SET key, it will bring up a menu screen. Use the arrow keys to navigate to to the right hand side of the screen, select “macro”. The press the select button for “soft op” (on the bottom on the screen). Use arrow keys to navigate down to PWE enabled, while hovering over PWE enabled type “1” then press insert. I believe a machine restart is required after.
    For the compensation go to the AI screen type 9990 then press page up. Backlash compensation should be in one of those menus.
    Good luck!
    Member andres-cuesta's Avatar
    May 2022
    Default Re: Fanuc Robocut alpha oc wire edm backlash compansation
    Does anuone knows if exist a PARAMETER MANUAL made for Fanuc for an Alpha 0-C with Fanuc 16-W controller?
    Jan 2017
    Mexico
    Quote Originally Posted by andres-cuesta View Post
    Did you find any manual for this Fanuc controller?
    Mar 2016
    Poland
    I have an operator manual, but there is nothing about parameters.
    Jan 2017
    Mexico
    Could you share it? I'll start looking for some of the parameters and I'll share it if I find it
  7. #7
    Mar 2016
    Poland
    Sure. Send me some e-mail address.
  8. #8
    Jan 2017
    Mexico
    What is your email, sorry? Mine is abraham.gutierrez@outlook.com
  9. #9
    Mar 2016
    Poland
    It's sent.
