- Random wire tilt?
*Registered User*
Random wire tilt?
Im having problems with my AgieCharmilles CUT 20P. Ive checked to see if the machine is level, table is level, wire is indicated, clamping is level, work piece is properly indicated, Di is clean, filters are clean, all consumables in lower and upper heads are either new or rotated. Ive run a simple circle punch program from Esprit software posted out to the CUT 20, and i still get the random tilt. Its concentric, and the dropped punch is perfectly on size, but the remaining wall stock on the left over work piece (measure with a pin micrometer) tells me the cut out is tilted. Here is the program ive run, hoping the reason for the tilt is in here...Please Help!!
M50;
G00 X.5 Y-1.25;
M60;
M34;
(ROUGH PRIMARY CUT);
G90 G92 X.5 Y-1.25;
C096;
G42 H000;
G01 X.5 Y-2.05;
G42 H001;
C001;
G03 X.47507 Y-2.44844 I0 J-.2;
G03 X.54948 Y-2.05622 I.02493 J.19844;
C097;
G40 H000 G50 A0 G01 X.55443 Y-2.03684;
G04 X2.0;
(SKIM PRIMARY CUT [ 1]);
G90 G92 X.55443 Y-2.03684;
C002;
G41 H000;
G01 X.54948 Y-2.05622;
G41 H002;
G02 X.47507 Y-2.44844 I-.04948 J-.19378;
G02 X.5 Y-2.05 I.02493 J.19844;
G40 H000 G50 A0 G01 X.5 Y-2.03;
(SKIM PRIMARY CUT [ 2]);
G90 G92 X.5 Y-2.03;
C003;
G42 H000;
G01 X.5 Y-2.05;
G42 H003;
M00;
(CUT-OFF PRIMARY CUT);
C097;
G42 H000;
G42 H001;
G03 X.5 Y-2.05 I-.04948 J-.19378;
M00;
M35;
M50;
M02;
- Random wire tilt?
- You may not post replies
- You may not edit your posts
Forum Rules
