- Need Help!- Help for Agie Charmilles Cut 30p and 20p
hello every one ...
before every think thank you for making such cooperative place to share ideas and helping each other as friends
i have cut 30p and 20p machines of agie charmilles
my first problem with these machines is that the axis when stops or starts moving there is a stroke which vibrated the whole tank. i want to know is it normal ?
my second problem is the dry run speed is very slow, even slower than G00, is there a way to increase that ?
my third problem is when i have to cut a part with multiple pass there is a problem in second pass, in one hand i experienced very slow machining in half of shape and on the other hand very fast machining on the other half. what can i do about this problem ? is there some sort of helper to setting parameters except the default technologies ?
best regards
- You may not post replies
- You may not edit your posts
Forum Rules
