- Robofil, Touch not Functioning, EDM Active in Manual Makes no Sparks
I'm having trouble getting my 510 machine up and running.
I've manually threaded a wire, and it feeds (although not super smooth). I have a resin bottle on the machine and the DI is < 15uS. I activate touch mode, and the machine wont move, except in the X- direction. it will move in X-. When I crash into something moving in X-, nothing happens, the machine doesnt stop.
Also, I'm trying to manually make a cut just to make sure things are working. I've activated the standard steel .TEC using CT-Expert for 0.01" wire. In manual mode, I press EDM active. This is supposed to produce a EDM signal in manual mode where it should make some sparks. For me, nothing happens when I do this. There are no alarms on the machine. Any thoughts?
Re: Robofil, Touch not Functioning, EDM Active in Manual Makes no Sparks
I did some additional things.
I setup the machine for a roughing operation by giving the REX, E1, H0.5 command. That seemed to make the machining parameter look better.
I also found out about taking an automated relative move cut by using the CTR command.
So, I programmed CTR, X-0.25, this all wanted to work, the injections all turned on, you heard the generator click on, but the machine just gives a wire short error and wont make the cut.
This seems related to the odd touch behavior. I can understand that the machine wont want to move in touch mode if there's a short, but why does it move in X- in that mode?
well, seems like there must be a short. or some false detection of a short. any ideas?
- You may not post replies
- You may not edit your posts
Forum Rules
