Need Help! 1998 Mits FX10K start up with rotary phase converter
Results 1 to 3 of 3
Thread: 1998 Mits FX10K start up with rotary phase converter
    Registered Jg-gonzo's Avatar
    Sep 2016
    Default 1998 Mits FX10K start up with rotary phase converter
    I bought a 1998 Mits FX10K from a company. I watched it run at the company. I have it all hooked up- thanks to another member!!!! and I need to run it off a phase converter. I have the converter- 10hp rotary,and the machine ready to wire. I have a concern about the legs of voltage. 2 are 110 and the manufactured leg is higher do I need to get something to equal out these legs before I power up? Some help on the way the wires need to connect to the machine would be a plus, which leg where.
    Gold Member Machineit's Avatar
    Mar 2010
    Default Re: 1998 Mits FX10K start up with rotary phase converter
    You just have to make sure that the two 110v legs are the ones that engage the solenoids. They are usually #1 and #3, but check. The important measurement after that is the voltage between legs, not legs to ground. The manufactured or wild leg will always be higher.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    May 2010
    Jg-gonzo
    Was the 10HP RPC adequate for your Mits FX10? Does it power your chiller through the FX10 wiring or is chiller on a separate circuit?
    What make & model of RPC did you use?
    Many thanks!
    Keith
