check your NC rack voltages. set 5 volts to 5.1 vdc measured at the backplane!!!!!!
check and replace your batteries on the UA+SAL board.
check your 24 vdc supply.
thats a start
If the power goes out, during the restart I get E070 execution inactive then E684 impossible operation. Which means I have lost my reference. My U axis is off by
aprox. .750, So I do a guide setup and life is good till the next time. Some times the machine will shut down, startup , shut down and start up when either the generator
or the pumps kick in with the same end result. I have replaced the K1 relay and went through all of the YV valves.
Any suggestions would be appreciated.
thats a start
Registered Linux User #348337
EMC2 Rocks!!!!
I checked the voltage on the SAL Restart board
5 v check 4.93
-12 checked 12.09
+12 checked 11.82
The battery checks 4.11 volts.
Hi. Do you still own this machine?
Sent from my D5803 using Tapatalk
