- Need Help!- Belmont Hole Popper
Belmont Hole Popper
Hello Guys,
I just bought a Belmont Hole Popper, used of course. I'm new to this type of machine.it comes with a ebbco dionizing unit and chiller. I've been told that you can use tap water or dionized water. Is this true? Is there anyone in here that is familiar with this type of machine. I believe it's a Maxsee S-26.
Thanks in advance.
Wiredude
Re: Belmont Hole Popper
Wiredude, you can fill your tank with tap water but you would need to circulate it a while to deionize it before you burn. How do you fill your wire reservior? We have leased DI tanks for the fill water to keep the resin usage under control.
You can also bypass the provided de-ionizing tank that uses bags from the in and out lines to hook up a DI tank. We use electrodes inc. for our tanks as they provide virgin resin.
- You may not post replies
- You may not edit your posts
Forum Rules
