Need Help! Agie Elox Mondo, Agie Futura
Results 1 to 4 of 4
Thread: Agie Elox Mondo, Agie Futura
    Oct 2015
    Default Agie Elox Mondo, Agie Futura
    Hello. I've got problem with Agie Futura. Everything is stopping at Bios screen.
    "CMOS system options not set
    CMOS display type mismatch
    Keyboard error
    Press F1 to resume"
    Anyone knows what is wrong?
    Attached Thumbnails Attached Thumbnails Agie Elox Mondo, Agie Futura-bc065d8f80b8cf61gen-png
    Oct 2015
    Default Re: Agie Elox Mondo, Agie Futura
    your motherboard battery is dead and therefore has lost CMOS programmed settings that Agie used to set up the machine.
    You will need to replace the battery and attach an AT style keyboard (large connector) to motherboard after replacing battery
    to reprogram CMOS settings. Changing the battery can be easy or difficult depending upon the motherboard. It may require
    unsoldering and resoldering. you can email me directly jddow@comcast.net
    Oct 2015
    your motherboard's battery is defective. you will need to change the battery. the battery on the motherboard is either a solder
    on or a round plug in.
    Oct 2015
    Now, the next questions.
    Machine lost its working parameters. How to set it back?
    Wys?ane z mojego NX569J przy u?yciu Tapatalka
    rafat's Avatar
    May 2020
    hellow,I've got problem with Agie Futura 2. Dilectric temperature has exceded 50 c......
    Z axis dosnot move
    how can I fix it
