Need Help! Problem tension wire machine sodick AQ535L
Results 1 to 3 of 3
Thread: Problem tension wire machine sodick AQ535L
    May 2011
    Mexico
    Default Problem tension wire machine sodick AQ535L
    Good day
    The procedure was performed for calibration
    without wire
    VOUT and GND = 60mV
    TENSENS and GND = 300mV
    As indicated in the procedure
    And turn on the machine. H00207 shows alarm. Tension abnormal press ENT to continue
    And after a few seconds. E00180 shows alarm. Excess discharge time (SH) press ACK
    Thanks for your time
    May 2011
    Mexico
    Default Re: Problem tension wire machine sodick AQ535L
    Quote Originally Posted by mayelo82 View Post
    Good day
    without wire
    VOUT and GND = 60mV
    When I turn on the machine is servo drive MSDA013D1A. marks (ERROR 14 Overcurrent)
    could this be the cause of the failure of the tension wire
    Member Chan6946's Avatar
    Dec 2019
    Having problem with condition 777 showing short-circuit been told to change the fuse no clue where the fuse is any help will be greatly appreciated
