well you are not really EDMing when the machine is in dry run, you are probably(definately) making contact between the wire and the work. so you have turned the machine into an eletronic bandsaw.
why don't you properly use the machine by stacking several inches tall of the thin sheet and edm them all at once, you should be able to burn about 750 of .004 material at once.
mac
