Hi
I bought a Brother 350 Wire EDM two years ago and it work very good.I had never used a wire edm before.I use Bobwire and it is very easy to use.
Does anyone have a brother hs-300 wirecut or similar model, i have just bought one and am after a bit of advice with the setup and ion settings.
I have never run one before so i am trying to follow the manual on settings but it quite vague, any help would be appreciated.
Hi
Hello.
Wondering if anyone knows where I may be able to get used or rebuilt boards for a (approx) 1988 Brother #HS-300 wire EDM machine??
Thanks,
De Maxwell - McKean Machinery Sales
hi do you know how to adjust the lcd screen brightness from the brother?
Hello all,
Same machine here, but cannot get electricity to turn on. When ELEC button is pressed, HIGH VOLTAGE light comes on and alarms out. Alarm is FET ERROR.
Thank you on advance.
I would appreciate it if someone could give me a copy of the Brother Communications software. It used to come with the machines on a floppy. It has a file called DHINST on it and that is what I need. When run, it sets up the Brother sub folder on your hard drive. Same for HS-100 and HS-300 etc.
Thanks in advance----Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
Duplicate post
Got the software, thanks SeymourDumore.
Mike
Does anyone have a Brother HS-300 SERVO CONTROL PCB ASSY for sell?
pmanoj
Hi.
This is Rao Umar from Pakistan. I have had a Brother HS-350 machine in non working condition for the last 6 years. There is a wiring problem in the machine. If you have a wiring manualof the machine. Requesting you to send me the diagram so that i can work on the machine.
Thanks in advance
