There is a problem with the plasma cutting machine. The next day after work, the z axis stopped working (it didn’t move up or down, but the movement indicators were on). After that, I replaced the controller and the axis motor, and a new error appeared. The controller gives an E0 error, which, judging by the instructions, does not even exist ...
Plasma source LGK300HD.
Perhaps someone has encountered such a problem and can suggest something.
Hello everybody.
With the error E0, to solve. It's the compatibility issue.
For the XPTHC-4H, all parts in the set must be changed.
After changing all the parts, the E0 error disappears and the system initializes correctly.
Unfortunately I can't solve the problem with the Z axis.
