retrofitted a 5 x 10 plasma table that was built by fast cut and ran dynatorch software. belt drive machine, was having issues with motors and dynatorch so went with fabcut/flash-cut set up. old motors were servo and new ones are stepper. i'm getting a lot of vibration and 'saw tooth' profile on cuts when X and Y are moving together. have been back and forth with fab-cut but couldn't get it to work better. we slowed down the cuts and helps a bit but something still wrong. someone suggested reducing torque on the motors?
3 AXIS 8 AMP PRO-SERIES MICROSTEPPING CONTROL
BOX INCLUDES:
( ) FLASHCUT CNC SOFTWARE
( ) (1) 3 AXIS 8 AMP MICROSTEPPING CONTROL BOX W/
70VDC POWER SUPPLY
MP-2303
NEMA 23, 454 OZ-IN STEPPER MOTOR WITH XLR
CONNECTOR AND STRAIN RELIEF
even when i rapid jog machine in x and y the head shakes, which gets me thinking motors have too much torque??
It sounds to me like the steppers are exhibiting a mid-band resonance. If they are running in full-step and even sometimes in half-step mode they can get a resonance
similar to what you describe.
What microstepping regime are you using? Most find the 8, 10 or 16 microsteps per full step is a good compromise between signalling speed and motion smoothness.
